Single Output Dependent Observability Normal Form - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2007
This paper gives the sufficient and necessary conditions which guarantee the existence of a diffeomorphism in order to transform a nonlinear system without inputs into a canonical normal form depending on its output. Moreover we extend our results to a class of systems with inputs.
Mots clés
Automatique
SIAM_HAL.pdf (188.47 Ko) Télécharger le fichier
inria-00179184 , version 1 (13-10-2007)
Gang Zheng, Driss Boutat, Jean-Pierre Barbot. Single Output Dependent Observability Normal Form. SIAM Journal on Control and Optimization, 2007, 46 (6), pp.2242-2255. ⟨10.1137/050627137⟩. ⟨inria-00179184⟩
350 Consultations
355 Téléchargements
