HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
A CMOS Image Sensor with on Chip Image Compression based on Predictive Boundary Adaptation and QTD Algorithm
Shoushun Chen 1 Amine Bermak Yan Wang Dominique Martinez 2
2 CORTEX - Neuromimetic intelligence
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : This paper presents the architecture, algorithm and VLSI hardware of image acquisition, storage and compression on a single-chip CMOS image sensor. The image array is based on time domain digital pixel sensor technology equipped with non-destructive storage capability using 8-bit Static-RAM device embedded at the pixel level. An adaptive quantization scheme based on Fast Boundary Adaptation Rule (FBAR) and Differential Pulse Code Modulation (DPCM) procedure followed by an on-line Quadrant Tree Decomposition (QTD) processing is proposed enabling a robust and compact image compression processor. A prototype chip including 64x64 pixels, read-out and control circuitry as well as the compression processor was implemented in 0.35um CMOS technology with a silicon area of 3.2x3.0 mm2. Simulation results show compression figures corresponding to 0.6-0.8 Bit-per-Pixel (BPP), while maintaining reasonable PSNR levels.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00180188
Contributor : Dominique Martinez Connect in order to contact the contributor
Submitted on : Thursday, October 18, 2007 - 9:21:36 AM
Last modification on : Friday, February 4, 2022 - 3:21:55 AM
Identifiers
  • HAL Id : inria-00180188, version 1
Collections
Citation
Shoushun Chen, Amine Bermak, Yan Wang, Dominique Martinez. A CMOS Image Sensor with on Chip Image Compression based on Predictive Boundary Adaptation and QTD Algorithm. the 6th IEEE SENSORS Conference, 2007, Atlanta, United States. ⟨inria-00180188⟩
Share
Metrics
Record views
83
