Journal articles
Gaussian Regularized Sliced Inverse Regression
Caroline Bernard-Michel 1 Laurent Gardes 1 Stephane Girard 1
1 MISTIS - Modelling and Inference of Complex and Structured Stochastic Systems
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann, INPG - Institut National Polytechnique de Grenoble
Abstract : Sliced Inverse Regression (SIR) is an effective method for dimension reduction in high-dimensional regression problems. The original method, however, requires the inversion of the predictors covariance matrix. In case of collinearity between these predictors or small sample sizes compared to the dimension, the inversion is not possible and a regularization technique has to be used. Our approach is based on a Fisher Lecture given by R.D. Cook where it is shown that SIR axes can be interpreted as solutions of an inverse regression problem. In this paper, a Gaussian prior distribution is introduced on the unknown parameters of the inverse regression problem in order to regularize their estimation. We show that some existing SIR regularizations can enter our framework, which permits a global understanding of these methods. Three new priors are proposed leading to new regularizations of the SIR method. A comparison on simulated data is provided.
Complete list of metadatas
Cited literature [33 references]  Display  Hide  Download
https://hal.inria.fr/inria-00180458
Contributor : Stephane Girard <>
Submitted on : Tuesday, April 23, 2013 - 10:44:25 AM
Last modification on : Thursday, March 26, 2020 - 8:49:30 PM
Document(s) archivé(s) le : Thursday, July 25, 2013 - 11:28:43 AM
File
sir_regul5.pdf
Identifiers
Collections
Citation
Caroline Bernard-Michel, Laurent Gardes, Stephane Girard. Gaussian Regularized Sliced Inverse Regression. Statistics and Computing, Springer Verlag (Germany), 2009, 19 (1), pp.85-98. ⟨10.1007/s11222-008-9073-z⟩. ⟨inria-00180458v3⟩
Share
Metrics
Record views
685
Files downloads
667
