Some new simulations schemes for the evaluation of Feynman-Kac representations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Monte Carlo Methods and Applications Année : 2008
We describe new variants of the Euler scheme and of the walk on spheres method for the Monte Carlo computation of Feynman-Kac representations. We optimize these variants using quantization for both source and boundary terms. Numerical tests are given on basic examples and on Monte Carlo versions of spectral methods for the Poisson equation. We especially introduce a new stochastic spectral formulation with very good properties in terms of conditioning.
quanti2007.pdf (231.91 Ko) Télécharger le fichier
inria-00182436 , version 1 (26-10-2007)
Sylvain Maire, Etienne Tanré. Some new simulations schemes for the evaluation of Feynman-Kac representations. Monte Carlo Methods and Applications, 2008, 14 (1), pp.29--51. ⟨10.1515/MCMA.2008.002⟩. ⟨inria-00182436⟩
265 Consultations
537 Téléchargements
