HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Engineering Multimedia Applications on the basis of Multi-Structured Descriptions of Audiovisual Contents
Marc Caillet 1, 2, * Cécile Roisin 1 Jean Carrive 2 François Yvon 3
* Corresponding author
1 WAM - Web, adaptation and multimedia
Inria Grenoble - Rhône-Alpes, LIG - Laboratoire d'Informatique de Grenoble
Abstract : We focus our interest on the engineering of multimedia applications whose purpose is to exploit and make best use of the audiovisual heritage by means of prospective exploration of virtual access to audiovisual documents through multi-structured descriptions of these. Multi-structured descriptions are composed of multiple descriptors that are expressed using the FDL (Feria Description Language) object language whose expressive power is emphasized. FDL notably provides a multimedia developer with operations on descriptions and their inner descriptors, as well as temporal aggregation data types. An experimental multimedia application that makes extensive use of FDL concepts and mechanisms is outlined. It explores the use of syncing between the narrative structure of the text of a play and the narrative structure of different broadcasted performances of this play, at multiple granularity levels.
Document type :
Conference papers
Complete list of metadata
Cited literature [34 references]  Display  Hide  Download
https://hal.inria.fr/inria-00189340
Contributor : Cécile Roisin Connect in order to contact the contributor
Submitted on : Tuesday, November 20, 2007 - 4:27:29 PM
Last modification on : Friday, February 4, 2022 - 3:24:20 AM
Long-term archiving on: : Monday, April 12, 2010 - 2:51:27 AM
File
SADPI-Caillet.pdf
Publisher files allowed on an open archive
Identifiers
  • HAL Id : inria-00189340, version 1
Collections
Citation
Marc Caillet, Cécile Roisin, Jean Carrive, François Yvon. Engineering Multimedia Applications on the basis of Multi-Structured Descriptions of Audiovisual Contents. Proceedings of the 2007 international workshop on Semantically aware document processing and indexing, May 2007, Montpellier, France. ⟨inria-00189340⟩
Share
Metrics
Record views
233
Files downloads
345
