Union of Reducibility Candidates for Orthogonal Constructor Rewriting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2008
We revisit Girard's reducibility candidates by proposing a general of the notion of neutral terms. They are the terms which do not interact with some contexts called elimination contexts. We apply this framework to constructor rewriting, and show that for orthogonal constructor rewriting, Girard's reducibility candidates are stable by union.
orth.pdf (213.5 Ko) Télécharger le fichier
inria-00204710 , version 1 (15-01-2008)
  • HAL Id : inria-00204710 , version 1
Colin Riba. Union of Reducibility Candidates for Orthogonal Constructor Rewriting. 2008. ⟨inria-00204710⟩
Collections
INRIA INRIA2
41 Consultations
229 Téléchargements
