A Variational Method for Scene Flow Estimation from Stereo Sequences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
This paper presents a method for scene flow estimation from a calibrated stereo image sequence. The scene flow contains the 3-D displacement field of scene points, so that the 2-D optical flow can be seen as a projection of the scene flow onto the images. We propose to recover the scene flow by coupling the optical flow estimation in both cameras with dense stereo matching between the images, thus reducing the number of unknowns per image point. The use of a variational framework allows us to properly handle discontinuities in the observed surfaces and in the 3-D displacement field. Moreover our approach handles occlusions both for the optical flow and the stereo. We obtain a partial differential equations system coupling both the optical flow and the stereo, which is numerically solved using an original multi-resolution algorithm. Whereas previous variational methods were estimating the 3-D reconstruction at time $t$ and the scene flow separately, our method jointly estimates both in a single optimization. We present numerical results on synthetic data with ground truth information, and we also compare the accuracy of the scene flow projected in one camera with a state-of-the-art single-camera optical flow computation method. Results are also presented on a real stereo sequence with large motion and stereo discontinuities. Source code and sample data are available for the evaluation of the algorithm.
iccv07.pdf (1.08 Mo) Télécharger le fichier
inria-00262139 , version 1 (11-03-2008)
Frédéric Huguet, Frédéric Devernay. A Variational Method for Scene Flow Estimation from Stereo Sequences. International Conference on Computer Vision, IEEE, Oct 2007, Rio de Janeiro, Brazil. ⟨10.1109/ICCV.2007.4409000⟩. ⟨inria-00262139⟩
586 Consultations
1345 Téléchargements
