Traffic Grooming in Unidirectional WDM Rings with Bounded Degree Request Graph - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Traffic grooming is a major issue in optical networks. It refers to grouping low rate signals into higher speed streams, in order to reduce the equipment cost. In SONET WDM networks, this cost is mostly given by the number of electronic terminations, namely ADMs. We consider the case when the topology is a unidirectional ring. In graph-theoretical terms, the traffic grooming problem in this case consists in partitioning the edges of a request graph into subgraphs with a maximum number of edges, while minimizing the total number of vertices of the decomposition. We consider the case when the request graph has bounded maximum degree $\Delta$, and our aim is to design a network being able to support any request graph satisfying the degree constraints. The existing theoretical models in the literature are much more rigid, and do not allow such adaptability. We formalize the problem, and solve the cases $\Delta=2$ (for all values of $C$) and $\Delta = 3$ (except the case $C=4$). We also provide lower and upper bounds for the general case.
RR-6481.pdf (282.61 Ko) Télécharger le fichier
inria-00265565 , version 1 (19-03-2008)
inria-00265565 , version 2 (20-03-2008)
  • HAL Id : inria-00265565 , version 2
  • ARXIV : 0803.2813
Xavier Muñoz. Traffic Grooming in Unidirectional WDM Rings with Bounded Degree Request Graph. [Research Report] RR-6481, INRIA. 2008. ⟨inria-00265565v2⟩
154 Consultations
147 Téléchargements
