Discussion on: Stabilization of Networked Control System with Time Delays and Data-packet Losses - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue European Journal of Control Année : 2007
Arben Cela
  • Fonction : Auteur
  • PersonId : 858447
Cosmin Ionete
  • Fonction : Auteur
In this paper, we provide experimental results in the application of the results of [4]. Based on the theoretic work in [4], we propose an estimator-based delaycompensation algorithm to stabilize a networked control system (NCS) with network-induced stochastic time delays, data-packet losses, and out-of-order data-packet transmissions. With the p-sampling-period delay upper bound, the NCS can also accommodate up to p – 1 successive packet losses. We also derive sufficient conditions for the stability of the NCS. The feasibility and effectiveness of the theoretic results of [4] is verified experimentally using an NCS test bed incorporating an open-loop unstable ball magnetic-levitation (maglev) system we constructed.
Automatique
Fichier non déposé
inria-00274633 , version 1 (20-04-2008)
Arben Cela, Mohamed El Mongi Ben Gaïd, Cosmin Ionete. Discussion on: Stabilization of Networked Control System with Time Delays and Data-packet Losses. European Journal of Control, 2007, 13 (4), ⟨10.3166/ejc.13.343-350⟩. ⟨inria-00274633⟩
107 Consultations
0 Téléchargements
