HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Modeling complex luminance variations for target tracking
Christophe Collewet 1 Eric Marchand 1, *
* Corresponding author
1 Lagadic - Visual servoing in robotics, computer vision, and augmented reality
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : Lambert's model is widely used in low level computer vision algorithms such as matching, tracking or optical flow computation for example. However, it is well known that these algorithms often fail when they face complex luminance variations. Therefore, we revise in this paper the underlying hypothesis of its temporal constancy and propose a new optical flow constraint. To do that, we use the Blinn-Phong reflection model to take into account that the scene may move with respect to the lighting and/or to the observer, and that specular highlights may occur. To validate in practice these analytical results, we consider the case where a camera is mounted on a robot end-effector with a lighting mounted on this camera and show experimental results of target tracking by visual servoing. Such an approach requires to analytically compute the luminance variations due to the observer motion which can be easily derived from our revised optical flow constraint. In addition, while the visual servoing classical approaches rely on geometric features, we present here a new method that directly relies on the luminance of all pixels in the image which does not require any tracking or matching process.
Document type :
Conference papers
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/inria-00304345
Contributor : Eric Marchand Connect in order to contact the contributor
Submitted on : Wednesday, July 23, 2008 - 8:54:45 AM
Last modification on : Tuesday, October 19, 2021 - 11:58:47 PM
Long-term archiving on: : Monday, May 31, 2010 - 9:10:41 PM
File
2008_cvpr_collewet.pdf
Identifiers
  • HAL Id : inria-00304345, version 1
Citation
Christophe Collewet, Eric Marchand. Modeling complex luminance variations for target tracking. IEEE Int. Conf. on Computer Vision and Pattern Recognition, Jun 2008, Anchorage, United States. ⟨inria-00304345⟩
Share
Metrics
Record views
269
Files downloads
94
