HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
The global k-means clustering algorithm
Abstract : We present the global k-means algorithm which is an incremental approach to clustering that dynamically adds one cluster at a time through a deterministic global search procedure consisting of N (with N being the size of the data set) executions of the k-means algorithm from suitable initial positions. We also propose modifications of the methods to reduce the computational load without significantly affecting solution quality. The proposed clustering methods are tested on well-known data sets and they compare favorably to the k-means algorithm with random restarts.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00321515
Contributor : Jakob Verbeek Connect in order to contact the contributor
Submitted on : Wednesday, February 16, 2011 - 5:03:46 PM
Last modification on : Monday, September 25, 2017 - 10:08:04 AM
Long-term archiving on: : Tuesday, May 17, 2011 - 2:38:06 AM
verbeek01tr.pdf
Identifiers
  • HAL Id : inria-00321515, version 1
Collections
Citation
Aristidis Likas, Nikos Vlassis, Jakob Verbeek. The global k-means clustering algorithm. [Technical Report] IAS-UVA-01-02, 2001, pp.12. ⟨inria-00321515⟩
Share
Metrics
Record views
381
Files downloads
12233
