Human Motion Tracking using a Color-Based Particle Filter Driven by Optical Flow - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In this paper, we present a new formulation for the problem of human motion tracking in video. Tracking is still a challenging problem when strong appearance changes occur as in videos of human in motion. Most trackers rely on a predefined template or on a training dataset to achieve detection and tracking. Therefore they are not efficient to track objects which appearance is not known in advance. A solution is to use an online method that updates iteratively a subspace of reference target models. In addition, we propose to integrate color and motion cues in a particle filter framework to track human body parts. The algorithm process consists in two modes, switching between detection and tracking. Detection steps involve trained classifiers to update estimated positions of the tracking windows, whereas tracking steps rely on an adaptative color-based particle filter coupled with optical flow estimations. The Earth Mover distance is used to compare color models in a global fashion, and constraints on flow features avoid drifting effects. The proposed method has revealed its efficiency to track body parts in motion and can cope with full appearance changes. Experiments were lead on challenging real world videos with poorly textured models and non-linear motions.
mlvma08_submission_15.pdf (858.62 Ko) Télécharger le fichier
inria-00326720 , version 1 (05-10-2008)
  • HAL Id : inria-00326720 , version 1
Tony Tung, Takashi Matsuyama. Human Motion Tracking using a Color-Based Particle Filter Driven by Optical Flow. The 1st International Workshop on Machine Learning for Vision-based Motion Analysis - MLVMA'08, Oct 2008, Marseille, France. ⟨inria-00326720⟩
Collections
MLVMA08
291 Consultations
377 Téléchargements
