FEMTO-ST - Franche-Comté Électronique Mécanique, Thermique et Optique - Sciences et Technologies (UMR 6174), Inria Nancy - Grand Est, LORIA - FM - Department of Formal Methods
Abstract : We address the insecurity problem for cryptographic protocols, for an active intruder and a bounded number of sessions. By modeling each protocol step as a rigid Horn clause, and the intruder abilities as an equational theory over a convergent rewrite system, the problem of active intrusion is formulated as a Cap Unification problem. Cap Unification is an extension of Equational Unification: we look for a cap to be placed on a given set of terms, so that it unifies with a given term modulo the equational theory.
Siva Anatharaman, Hai Lin, Chris Lynch, Paliath Narendran, Michael Rusinowitch. Active Intruders with Caps. FCS-ARSPA-WITS'08, Jun 2008, Pittsburgh, United States. ⟨inria-00330532⟩
