Abstract : Experimental validation and testing of solutions designed for heterogeneous environment is a challenging issue. Wrekavoc is a tool for performing such validation. It runs an unmodified applications on emulated multisite heterogeneous platforms. It downgrades the performance of the nodes (CPU and memory) and the interconnection network in a prescribed way. We report on new strategies to improve the accuracy of the network and memory models. Then, we present an experimental validation of the tool that compares executions of a variety of application code. The comparison is done between a real heterogeneous platform against the emulation of that platform with Wrekavoc. The measurements show that our approach allows for a close reproduction of the real measurements in the emulator.
https://hal.inria.fr/inria-00331627 Contributor : Jens GustedtConnect in order to contact the contributor Submitted on : Tuesday, October 21, 2008 - 6:00:25 PM Last modification on : Saturday, June 25, 2022 - 7:43:28 PM Long-term archiving on: : Tuesday, October 9, 2012 - 1:57:50 PM
