Conservative Adaptation in Metric Spaces - Archive ouverte HAL Access content directly
Conference Papers Year : 2008
(1) , (1)
1
Julien Cojan
  • Function : Author
  • PersonId : 836380
Jean Lieber
Conservative adaptation consists in a minimal change on a source case to be consistent with the target case, given the domain knowledge. It has been formalised in a previous work thanks to the AGM theory of belief revision applied to propositional logic. However, this formalism is rarely used in case-based reasoning systems. In this paper, conservative adaptation is extended to a more general representation framework, that includes also attribute-value formalisms. In this framework, a case is a class of case instances, which are elements of a metric space. Conservative adaptation is formalised in this framework and is extended to α-conservative adaptation, that relaxes the conservativeness. These approaches to adaptation in a metric space transform adaptation problems to well-formulated optimization problems. A running example in the cooking domain is used to illustrate the notions that are introduced.
articleECCBR08.pdf (181.38 Ko) Télécharger le fichier
Dates and versions
inria-00336043 , version 1 (31-10-2008)
Identifiers
Cite
Julien Cojan, Jean Lieber. Conservative Adaptation in Metric Spaces. 9th European Conference on Case-Based Reasoning - ECCBR 2008, Sep 2008, Trier, Germany. pp.135-149, ⟨10.1007/978-3-540-85502-6⟩. ⟨inria-00336043⟩
97 View
293 Download
Share
