On the compact formulation of the derivation of a transfer matrix with respect to another matrix - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
A new operator is considered, allowing compact formulae and proofs in the context of the derivation of a transfer matrix with respect to another matrix. The problem of the parametric sensitivity matrix calculation is chosen for illustration. It consists in deriving a Multiple Input Multiple Output transfer function with respect to a parametric matrix and is central in robust control theory. Efficient algorithms may be straightforwardly got from the compact analytic formulae using the operator introduced.
Automatique
RR-6760.pdf (187.03 Ko) Télécharger le fichier
inria-00345508 , version 1 (09-12-2008)
  • HAL Id : inria-00345508 , version 1
Thibault Hilaire, Philippe Chevrel. On the compact formulation of the derivation of a transfer matrix with respect to another matrix. [Research Report] RR-6760, INRIA. 2008. ⟨inria-00345508⟩
283 Consultations
183 Téléchargements
