Tunable parallel experiments in a GridRPC framework: application to linear solvers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
The use of scientific computing centers becomes more and more difficult on modern parallel architectures. Users must face a large variety of batch systems (with their own specific syntax) and have to set many parameters to tune their applications (e.g., processors and/or threads mapping, memory resource constraints). Moreover, finding the optimal performance is not the only criteria when a pool of jobs is submitted on the Grid (for numerical parametric analysis for instance) and one must focus on the wall-time completion. In this work we tackle the problem by using the D IET Grid middleware that integrates an adaptable PaStiX service to solve a set of experiments issued from the simulations of the ASTER project.
Fichier non déposé
inria-00346611 , version 1 (11-12-2008)
  • HAL Id : inria-00346611 , version 1
Yves Caniou, Jean-Sebastien Gay, Pierre Ramet. Tunable parallel experiments in a GridRPC framework: application to linear solvers. VECPAR'08, 2008, Toulouse, France. pp.46--52. ⟨inria-00346611⟩
80 Consultations
0 Téléchargements
