HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Visual servoing from spheres using a spherical projection model
R. Tatsambon Fomena 1 François Chaumette 1
1 Lagadic - Visual servoing in robotics, computer vision, and augmented reality
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : In this paper, we investigate the use of a spherical projection model to search for optimal visual features for visual servoing. A new minimal set of three visual features is proposed for visual servoing from spheres using any central catadioptric system. Using this set of features, a classical control method is proved to be globally stable even in the presence of modeling error and locally stable to calibration errors on perspective cameras. Using this type of cameras, experimental results are presented and validate the proposed theoretical results.
Document type :
Conference papers
Complete list of metadata
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/inria-00350747
Contributor : Eric Marchand Connect in order to contact the contributor
Submitted on : Wednesday, January 7, 2009 - 3:53:39 PM
Last modification on : Thursday, January 20, 2022 - 4:20:33 PM
Long-term archiving on: : Tuesday, June 8, 2010 - 6:56:46 PM
File
2007_icra_tatsambon.pdf
Identifiers
  • HAL Id : inria-00350747, version 1
Citation
R. Tatsambon Fomena, François Chaumette. Visual servoing from spheres using a spherical projection model. IEEE Int. Conf. on Robotics and Automation, ICRA'07, 2007, Roma, Italy. pp.2080-2085. ⟨inria-00350747⟩
Share
Metrics
Record views
110
Files downloads
172
