New interface
Conference papers
Tasks sequencing for visual servoing
Nicolas Mansard 1 François Chaumette 1
1 Lagadic - Visual servoing in robotics, computer vision, and augmented reality
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : Classical visual servoing approaches tend to constrain all degrees of freedom (DOF) of the robot during a task s execution. This may lead to singularities, force the robot into its joint limits or allow the visual features to leave the image. In this article a new approach is proposed. The key idea of this work is to control the robot with a very under-constrained task when it is far of the desired position, and to incrementally constrain the global task by adding further tasks as the robot moves closer to the goal. A method is first proposed that stacks elementary tasks until the robot is fully constrained. To insure the continuity of the articular velocities when adding constraints, a new control law is then proposed. Experiments that prove the interest of the approach are also provided.
Document type :
Conference papers
Complete list of metadata
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/inria-00352028
Contributor : Eric Marchand Connect in order to contact the contributor
Submitted on : Monday, January 12, 2009 - 1:53:27 PM
Last modification on : Thursday, January 20, 2022 - 4:20:26 PM
Long-term archiving on: : Tuesday, June 8, 2010 - 7:31:57 PM
File
2004_iros_mansard.pdf
Identifiers
  • HAL Id : inria-00352028, version 1
Citation
Nicolas Mansard, François Chaumette. Tasks sequencing for visual servoing. IEEE/RSJ Int. Conf. on Intelligent Robots and Systems, IROS'04, 2004, Sendai, Japan. pp.992-997. ⟨inria-00352028⟩
Share
Metrics
Record views
155
Files downloads
235
