Computer animation: a new application for image-based visual servoing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
This paper presents a new application for image-based visual servoing: computer graphics animation. Indeed, the control of a virtual camera in virtual environment is not a trivial problem and usually required skilled operators. Visual servoing, a now well known technique in robotics and computer vision, consists in positioning a camera according to the informations perceived in the images. Using this method within computer graphics context leads to a very intuitive approach of animation. Furthermore, in that case a full knowledge about the scene is available. It allows to easily introduce constraints within the control law in order to react automatically to modifications of the environment. In this paper, we apply this approach in two different contexts: highly reactive applications (virtual reality, video games) and the control of humanoid avatars.
2001_icra_courty.pdf (508.08 Ko) Télécharger le fichier
inria-00352120 , version 1 (12-01-2009)
  • HAL Id : inria-00352120 , version 1
Nicolas Courty, E. Marchand. Computer animation: a new application for image-based visual servoing. IEEE Int. Conf. on Robotics and Automation, ICRA'01, 2001, Seoul, South Korea. pp.223-228. ⟨inria-00352120⟩
194 Consultations
149 Téléchargements
