On Approximating Multi-Criteria TSP
We present approximation algorithms for almost all variants of the multi-criteria traveling salesman problem (TSP), whose performances are independent of the number $k$ of criteria and come close to the approximation ratios obtained for TSP with a single objective function. We present randomized approximation algorithms for multi-criteria maximum traveling salesman problems (\maxtsp). For multi-criteria \maxstsp, where the edge weights have to be symmetric, we devise an algorithm that achieves an approximation ratio of $2/3 - \eps$. For multi-criteria \maxatsp, where the edge weights may be asymmetric, we present an algorithm with an approximation ratio of $1/2 - \eps$. Our algorithms work for any fixed number $k$ of objectives. To get these ratios, we introduce a decomposition technique for cycle covers. These decompositions are optimal in the sense that no decomposition can always yield more than a fraction of $2/3$ and $1/2$, respectively, of the weight of a cycle cover. Furthermore, we present a deterministic algorithm for bi-criteria \maxstsp\ that achieves an approximation ratio of $61/243 \approx 1/4$. Finally, we present a randomized approximation algorithm for the asymmetric multi-criteria minimum TSP with triangle inequality (\minatsp). This algorithm achieves a ratio of $\log n + \eps$. For this variant of multi-criteria TSP, this is the first approximation algorithm we are aware of. If the distances fulfil the $\gamma$-triangle inequality, its ratio is $1/(1-\gamma) + \eps$.
Complexité [cs.CC]
