Rigid Shape Interpolation Using Normal Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In this paper we provide a new compact formulation of rigid shape interpolation in terms of normal equations, and propose several enhancements to previous techniques. Specifically, we propose 1) a way to improve mesh independence, making the interpolation result less influenced by variations in tessellation, 2) a faster way to make the interpolation symmetric, and 3) simple modifications to enable controllable interpolation. Finally we also identify 4) a failure mode related to large rotations that is easily triggered in practical use, and we present a solution for this as well.
Baxter-RigidMorphing-NPAR08.pdf (492.4 Ko) Télécharger le fichier
Format : Figure, Image
inria-00360532 , version 1 (09-06-2011)
  • HAL Id : inria-00360532 , version 1
William Baxter, Pascal Barla, Ken-Ichi Anjyo. Rigid Shape Interpolation Using Normal Equations. Proc. Non-Photorealistic Animation and Rendering, Jun 2008, Annecy, France. ⟨inria-00360532⟩
311 Consultations
1368 Téléchargements
