Gossip-based computation of a Gaussian mixture model for distributed multimedia indexing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Multimedia Année : 2008
The present paper deals with pattern recognition in a distributed computing context of the peer-to-peer type, that should be more and more interesting for multimedia data indexing and retrieval. Our goal is estimating of classconditional probability densities, that take the form of Gaussian mixture models (GMM). Originally, we propagate GMMs in a decentralized fashion (gossip) in a network, and aggregate GMMs from various sources, through a technique that only involves little computation and that makes parcimonious usage of the network resource, as model parameters rather than data are transmitted. The aggregation is based on iterative optimization of an approximation of a KL divergence allowing closed-form computation between mixture models. Experimental results demonstrate the scheme to the case of speaker recognition.
MM001325_revised.pdf (241.16 Ko) Télécharger le fichier
inria-00368854 , version 1 (17-03-2009)
  • HAL Id : inria-00368854 , version 1
Afshin Nikseresht, Marc Gelgon. Gossip-based computation of a Gaussian mixture model for distributed multimedia indexing. IEEE Transactions on Multimedia, 2008, 10 (3), pp.385-392. ⟨inria-00368854⟩
212 Consultations
248 Téléchargements
