New interface
Conference papers
Contextual Image Compression from Adaptive Sparse Data Representations
Abstract : Natural images contain crucial information in sharp geometrical boundaries between objects. Therefore, their description by smooth isotropic function spaces (e.g. Sobolev or Besov spaces) is not sufficiently accurate. Moreover, methods known to be optimal for such isotropic spaces (tensor product wavelet decompositions) do not provide optimal nonlinear approximations for piecewise smooth bivariate functions. Among the geometrybased alternatives that were proposed during the last few years, adaptive thinning methods work with continuous piecewise affine functions on anisotropic triangulations to construct sparse representations for piecewise smooth bivariate functions. In this article, a customized compression method for coding the sparse data information, as output by adaptive thinning, is proposed. The compression method is based on contextual encoding of both the sparse data positions and their attached luminance values. To this end, the structural properties of the sparse data representation are essentially exploited. The resulting contextual image compression method of this article outperforms our previous methods (all relying on adaptive thinning) quite significantly. Moreover, our proposed compression method also outperforms JPEG2000 for selected natural images, at both low and middle bitrates, as this is supported by numerical examples in this article.
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/inria-00369491
Contributor : Ist Rennes Connect in order to contact the contributor
Submitted on : Friday, March 20, 2009 - 9:57:18 AM
Last modification on : Friday, August 5, 2022 - 3:05:12 PM
Long-term archiving on: : Thursday, June 10, 2010 - 5:26:44 PM
File
25.pdf
Identifiers
  • HAL Id : inria-00369491, version 1
Collections
Citation
Laurent Demaret, Armin Iske, Wahid Khachabi. Contextual Image Compression from Adaptive Sparse Data Representations. SPARS'09 - Signal Processing with Adaptive Sparse Structured Representations, Inria Rennes - Bretagne Atlantique, Apr 2009, Saint Malo, France. ⟨inria-00369491⟩
Share
Metrics
Record views
161
Files downloads
200
