Reports
Equilibrium in size-based scheduling systems
Sébastien Soudan 1 Dinil Mon Divakaran 1 Eitan Altman 2 Pascale Vicat-Blanc Primet 1
1 RESO - Protocols and softwares for very high-performance network
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
2 MAESTRO - Models for the performance analysis and the control of networks
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : Size-based scheduling is advocated to improve response times of small flows. While researchers continue to explore different ways of giving preferential treatment to small flows without causing starvation to other flows, little focus has been paid to the study of stability of systems that deploy size-based scheduling mechanisms. The question on stability arises from the fact that, users of such a system can exploit the scheduling mechanism to their advantage and split large flows into multiple small flows. Consequently, a large flow in the disguise of small flows, may get the advantage aimed for small flows. As the number of misbehaving users can grow to a large number, an operator would like to learn about the system stability before deploying size-based scheduling mechanism, to ensure that it won't lead to an unstable system. In this paper, we analyse the criteria for the existence of equilibria and reveal the constraints that must be satisfied for the stability of equilibrium points. Our study exposes that, in a two-player game, where the operator strives for a stable system, and users of large flows behave to improve delay, size-based scheduling doesn't achieve the goal of improving response time of small flows.
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/inria-00371391
Contributor : Dinil Mon Divakaran Connect in order to contact the contributor
Submitted on : Friday, March 27, 2009 - 4:56:12 PM
Last modification on : Thursday, January 20, 2022 - 4:14:14 PM
Long-term archiving on: : Friday, October 12, 2012 - 2:26:55 PM
File
RR-6888.pdf
Identifiers
  • HAL Id : inria-00371391, version 1
Collections
Citation
Sébastien Soudan, Dinil Mon Divakaran, Eitan Altman, Pascale Vicat-Blanc Primet. Equilibrium in size-based scheduling systems. [Research Report] RR-6888, INRIA. 2009. ⟨inria-00371391⟩
Share
Metrics
Record views
98
Files downloads
69
