Benchmarking the NEWUOA on the BBOB-2009 Noisy Testbed - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
The NEWUOA which belongs to the class of Derivative-Free optimization algorithms is benchmarked on the BBOB-2009 noisy testbed. A multistart strategy is applied with a maximum number of function evaluations of 10^4 times the search space dimension.
wk2034-ros.pdf (744.25 Ko) Télécharger le fichier
inria-00377083 , version 1 (20-04-2009)
  • HAL Id : inria-00377083 , version 1
Raymond Ros. Benchmarking the NEWUOA on the BBOB-2009 Noisy Testbed. GECCO, Jul 2009, Montréal, Canada. ⟨inria-00377083⟩
106 Consultations
127 Téléchargements
