GRAVIR - IMAG - Laboratoire d'informatique GRAphique, VIsion et Robotique de Grenoble, Inria Grenoble - Rhône-Alpes, CNRS - Centre National de la Recherche Scientifique : FR71
Abstract : In this paper we propose a solution of the Lambertian Shape-From-Shading (SFS) problem by designing a new mathematical framework based on the notion of viscosity solution. The power of our approach is twofolds: 1) it defines a notion of weak solutions (in the viscosity sense) which does not necessarily require boundary data. Moreover, it allows to characterize the viscosity solutions by their minimums"; 2) it unifies the works of Rouy and Tourin, Falcone et al., Prados and Faugeras, based on the notion of viscosity solutions and the work of Dupuis and Oliensis dealing with classical solutions.
https://hal.inria.fr/inria-00377394 Contributor : Emmanuel PradosConnect in order to contact the contributor Submitted on : Tuesday, April 21, 2009 - 4:36:44 PM Last modification on : Thursday, March 17, 2022 - 10:08:31 AM Long-term archiving on: : Thursday, June 10, 2010 - 6:32:53 PM
