A variance reduction technique using a quantized Brownian motion as a control variate - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Journal of Computational Finance Année : 2012
This article presents a new variance reduction technique for diffusion processes where a control variate is constructed using a quantization of the coefficients of the Karhunen-Loève decomposition of the underlying Brownian motion. This method may be indeed used for other Gaussian processes.
reduction-variance-quantization-3.pdf (538.67 Ko) Télécharger le fichier
inria-00393749 , version 1 (09-06-2009)
inria-00393749 , version 2 (18-04-2010)
inria-00393749 , version 3 (08-11-2010)
  • HAL Id : inria-00393749 , version 3
Antoine Lejay, Victor Reutenauer. A variance reduction technique using a quantized Brownian motion as a control variate. The Journal of Computational Finance, 2012, 16 (2), pp.61-84. ⟨inria-00393749v3⟩
334 Consultations
534 Téléchargements
