Dynamic Skinning: Adding Real-time Dynamic Effects to an Existing Character Animation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
This paper proposes a simple and efficient technique to enhance classical animations of characters by adding a dynamic response of the skin to the movement of the underlying skeleton. The dynamic effects are locally added to the shape obtained through the standard skinning by specifying flesh elements. Our solution relies on a new second skinning operation that blends the current flesh volume computed through smooth skinning with its position in a dynamic frame attached to the skeleton through a visco-elastic element which, combined with a set of weights, controls the local behavior of tissues. We show how the weights can be automatically computed, taking into account the morphology of the limb. The resulting real-time technique is well suited to video games or any application where we need to add dynamic effects, at almost no cost, to an existing animation sequence.
Mots clés
Larboulette.Caroline.Full.03.pdf (533.58 Ko) Télécharger le fichier
cat_jumping_running.avi (3.06 Mo) Télécharger le fichier
eve_4flesh_elements.avi (2.67 Mo) Télécharger le fichier
mushroom_dynamic_skinning_and_mass_spring.avi (4.16 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
Format : Vidéo
Format : Vidéo
inria-00402599 , version 1 (23-05-2011)
Caroline Larboulette, Marie-Paule Cani, Bruno Arnaldi. Dynamic Skinning: Adding Real-time Dynamic Effects to an Existing Character Animation. 21st Spring Conference on Computer Graphics (SCCG '05), May 2005, Budmerice Castle, Slovakia. pp.87-93, ⟨10.1145/1090122.1090138⟩. ⟨inria-00402599⟩
620 Consultations
2211 Téléchargements
