DiaSim: A Parameterized Simulator for Pervasive Computing Applications - Archive ouverte HAL Access content directly
Conference Papers Year : 2009
(1) , (1) , (1)
1
Pervasive computing applications involve both software concerns, like any software system, and integration concerns, for the constituent networked devices of the pervasive computing environment. This situation is problematic for testing because it requires acquiring, testing and interfacing a variety of software and hardware entities. This process can rapidly become costly and time-consuming when the target environment involves many entities. In this demonstration, we present DiaSim, a simulator for pervasive computing applications. To cope with widely heterogeneous entities, DiaSim is parameterized with respect to a description of a target pervasive computing environment. This description is used to generate both a programming framework to develop the simulation logic and an emulation layer to execute applications. Furthermore, a simulation renderer is coupled to DiaSim to allow a simulated pervasive system to be visually monitored and debugged.
DiaSim.pdf (931.48 Ko) Télécharger le fichier
Dates and versions
inria-00403421 , version 1 (10-07-2009)
Identifiers
  • HAL Id : inria-00403421 , version 1
Cite
Julien Bruneau, Wilfried Jouve, Charles Consel. DiaSim: A Parameterized Simulator for Pervasive Computing Applications. Mobiquitous'09 - 6th International Conference on Mobile and Ubiquitous Systems: Computing, Networking and Services, Jul 2009, Toronto, Canada. ⟨inria-00403421⟩
Collections
CNRS INRIA INRIA2
166 View
456 Download
Share
