A hypergraph-based model for graph clustering: application to image indexing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper, we introduce a prototype-based clustering algorithm dealing with graphs. We propose a hypergraph-based model for graph data sets by allowing clusters overlapping. More precisely, in this representation one graph can be assigned to more than one cluster. Using the concept of the graph median and a given threshold, the proposed algorithm detects automatically the number of classes in the graph database. We consider clusters as hyperedges in our hypergraph model and we define a retrieval technique indexing the database with hyperedge centroids. This model is interesting to travel the data set and efficient to cluster and retrieve graphs.
paper240.pdf (299.45 Ko) Télécharger le fichier
inria-00404323 , version 1 (16-07-2009)
Salim Jouili, Salvatore Tabbone. A hypergraph-based model for graph clustering: application to image indexing. The 13th International Conference on Computer Analysis of Images and Patterns, Sep 2009, Munster, Germany. pp.360-368, ⟨10.1007/978-3-642-03767-2_44⟩. ⟨inria-00404323⟩
105 Consultations
590 Téléchargements
