Conference papers
IQ imbalance reduction in a SMI multi-antenna receiver by using a code multiplexing front-end
Matthieu Gautier 1 Pierre-Francois Morlat 1 Guillaume Villemaud 1
1 SWING - Smart Wireless Networking
Inria Grenoble - Rhône-Alpes, CITI - CITI Centre of Innovation in Telecommunications and Integration of services
Abstract : In this paper, we address the IQ imbalance sensibility of the code multiplexing front-end architecture. This innovative architecture has been recently proposed in order to reduce the analog complexity of an antenna diversity receiver front-end. An interesting characteristic of this structure is that the resulting IQ imbalance is equal for each received baseband signal. Associated with Single Matrix Inversion algorithm, this property ensures a high IQ imbalance robustness. A global antenna diversity system including analog front-end and digital processing has been implemented in order to perform simulation validation. Results show that the bit error rate does not increase significantly with the multiplexing and this increase is compensated for a high IQ imbalance.
Document type :
Conference papers
Complete list of metadata
Cited literature [9 references]  Display  Hide  Download
https://hal.inria.fr/inria-00412044
Contributor : Guillaume Villemaud Connect in order to contact the contributor
Submitted on : Friday, November 27, 2009 - 3:59:28 PM
Last modification on : Friday, February 4, 2022 - 3:11:22 AM
Long-term archiving on: : Tuesday, June 15, 2010 - 10:57:42 PM
File
VTC_spring09.pdf
Identifiers
  • HAL Id : inria-00412044, version 1
Collections
Citation
Matthieu Gautier, Pierre-Francois Morlat, Guillaume Villemaud. IQ imbalance reduction in a SMI multi-antenna receiver by using a code multiplexing front-end. IEEE VTC Spring 2009, Apr 2009, Barcelona, Spain. ⟨inria-00412044⟩
Share
Metrics
Record views
203
Files downloads
172
