Embedded Evolutionary Robotics: The (1+1)-Restart-Online Adaptation Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper deals with online onboard behavior optimization for an autonomous mobile robot in the scope of the European FP7 Symbrion Project. The work presented here extends the (1+1)-online algorithm introduced in earlier publication. This algorithm is a variation of a famous Evolution Strategies adapted to autonomous robots. In this paper, we address a limitation of this algorithm regarding the ability to perform global search whenever a local optimum is reached. A new implementation of the algorithm, termed (1+1)-restart-online algorithm, is described and implemented within the Symbrion robotic Cortex M3 microcontroller. Results from the experiments show that the new algorithm is able to escape local optima and, as a consequence, converge faster and provides a richer set of relevant controllers.
evoderob09montanier.pdf (2.6 Mo) Télécharger le fichier
inria-00413357 , version 1 (03-11-2009)
  • HAL Id : inria-00413357 , version 1
Jean-Marc Montanier, Nicolas Bredeche. Embedded Evolutionary Robotics: The (1+1)-Restart-Online Adaptation Algorithm. Workshop on Exploring new horizons in Evolutionary Design of Robots at IROS 2009, 2009, Saint Louis, United States. pp.37-43. ⟨inria-00413357⟩
105 Consultations
171 Téléchargements
