Protecting Data Privacy in Structured P2P Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
P2P systems are increasingly used for efficient, scalable data sharing. Popular applications focus on massive file sharing. However, advanced applications such as online communities (e.g., medical or research communities) need to share private or sensitive data. Currently, in P2P systems, untrusted peers can easily violate data privacy by using data for malicious purposes (e.g., fraudulence, profiling). To prevent such behavior, the well accepted Hippocratic database principle states that data owners should specify the purpose for which their data will be collected. In this paper, we apply such principles as well as reputation techniques to support purpose and trust in structured P2P systems. Hippocratic databases enforce purpose-based privacy while reputation techniques guarantee trust. We propose a P2P data privacy model which combines the Hippocratic principles and the trust notions. We also present the algorithms of PriServ, a DHT-based P2P privacy service which supports this model and prevents data privacy violation. We show, in a performance evaluation, that PriServ introduces a small overhead.
GLOBE09.pdf (1.07 Mo) Télécharger le fichier
inria-00414050 , version 1 (07-09-2009)
Paternité
  • HAL Id : inria-00414050 , version 1
Mohamed Jawad, Patricia Serrano-Alvarado, Patrick Valduriez. Protecting Data Privacy in Structured P2P Networks. Second International Conference on Data Management in Grid and P2P Systems (Globe 2009), Sep 2009, Linz, Austria. pp.85-98. ⟨inria-00414050⟩
295 Consultations
261 Téléchargements
