Book sections
E-Learning Systems Re-Engineering : Functional Specifications and Component-Based Architecture
Abstract : In this chapter we propose functional specifications and a component-based architecture for designing e-learning platforms. An important feature is that the proposed specifications and architecture are based on the experience gained in an e-learning company and result from a reengineering process. To guide the reengineering process, we used two reference models, which are the e-learning global process and the e-learning global cycle. The functional specifications are described according to the e-learning global cycle phases and they are used to propose a software component based architecture. The proposed kernel of components was completed with services to allow interoperability and standard compliance between several e-learning platforms. We hope that this case-study examplifies e-learning platform suppliers' needs and available pragmatic solutions. We conclude on foreseeable evolutions of e-learning actors needs and practices and on new platform features for fulfilling such needs.
Complete list of metadata
https://hal.inria.fr/inria-00414376
Contributor : Monique Grandbastien Connect in order to contact the contributor
Submitted on : Tuesday, September 8, 2009 - 6:40:43 PM
Last modification on : Saturday, October 16, 2021 - 11:26:08 AM
Identifiers
  • HAL Id : inria-00414376, version 1
Citation
Lahcen Oubahssi, Monique Grandbastien. E-Learning Systems Re-Engineering : Functional Specifications and Component-Based Architecture. Claus Pahl. Architecture Solutions for E-Learning Systems, IGI Global, 409 p., 2008, 978-1-59904-633-4. ⟨inria-00414376⟩
Share
Metrics
Les métriques sont temporairement indisponibles
