New Anonymity Notions for Identity-Based Encryption - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Identity-based encryption is a very convenient tool to avoid key management. Recipient-privacy is also a major concern nowadays. To combine both, anonymous identity-based encryption has been proposed. This paper extends this notion to stronger adversaries (the authority itself). We discuss this new notion, together with a new kind of non-malleability with respect to the identity, for several existing schemes. Inter- estingly enough, such a new anonymity property has an independent application to password-authenticated key exchange. We thus come up with a new generic framework for password-authenticated key exchange, and a concrete construction based on pairings.
2008_scnB.pdf (298.51 Ko) Télécharger le fichier
inria-00419152 , version 1 (22-09-2009)
  • HAL Id : inria-00419152 , version 1
Malika Izabachène, David Pointcheval. New Anonymity Notions for Identity-Based Encryption. SCN '08, 2008, Amalfi, Italie, Italy. pp.375--391. ⟨inria-00419152⟩
69 Consultations
184 Téléchargements
