Switching controller for stabilization of linear systems with switched time-varying delays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper considers interval time-varying delay systems with delayed estimation of the delay. This case is often encountered in the Networked Control Systems (NCS) field. Based on Lyapunov-Krasovskii functional methods and linear matrix inequality (LMI) techniques, a switching state feedback controller is designed to guarantee the exponential stability. The controller switches according to the measured time-delay which is itself delayed. The global stability of the switching closed loop is guaranteed if some dwell time conditions are satisfied.
cdc09_wjefakjpr.pdf (223.59 Ko) Télécharger le fichier
inria-00419360 , version 1 (23-12-2009)
  • HAL Id : inria-00419360 , version 1
Wenjuan Jiang, Emilia Fridman, Alexandre Kruszewski, Jean-Pierre Richard. Switching controller for stabilization of linear systems with switched time-varying delays. CDC'09, 48th IEEE Conf. on Decision and Control, Dec 2009, Shanghai, China. ⟨inria-00419360⟩
477 Consultations
327 Téléchargements
