Mesh generation from 3D multi-material images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Dobrina Boltcheva
  • Fonction : Auteur
  • PersonId : 863010
Mariette Yvinec
Jean-Daniel Boissonnat
  • Fonction : Auteur
  • PersonId : 830857
The problem of generating realistic computer models of objects represented by 3D segmented images is important in many biomedical applications. Labelled 3D images impose particular challenges for meshing algorithms because multi-material junctions form features such as surface pacthes, edges and corners which need to be preserved into the output mesh. In this paper, we propose a feature preserving Delaunay refinement algorithm which can be used to generate high-quality tetrahedral meshes from segmented images. The idea is to explicitly sample corners and edges from the input image and to constrain the Delaunay refinement algorithm to preserve these features in addition to the surface patches. Our experimental results on segmented medical images have shown that, within a few seconds, the algorithm outputs a tetrahedral mesh in which each material is represented as a consistent submesh without gaps and overlaps. The optimization property of the Delaunay triangulation makes these meshes suitable for the purpose of realistic visualization or finite element simulations.
MICCAI09_boltcheva.pdf (1.16 Mo) Télécharger le fichier
inria-00420228 , version 1 (28-09-2009)
Dobrina Boltcheva, Mariette Yvinec, Jean-Daniel Boissonnat. Mesh generation from 3D multi-material images. MICCAI 2009 - 12th International Medical Image Computing and Computer-Assisted Intervention, Sep 2009, Londres, United Kingdom. ⟨10.1007/978-3-642-04271-3⟩. ⟨inria-00420228⟩
Collections
INRIA INRIA2
392 Consultations
755 Téléchargements
