New interface
Conference papers
Logic-Based XPath Optimization
Abstract : XPath was introduced by the W3C as a standard language for specifying node selection, matching conditions, and for computing values from an XML document. XPath is now used in many XML standards such as XSLT and the forthcoming XQuery database access language. Since efficient XML content querying is crucial for the performance of almost all XML processing architectures, a growing need for studying high performance XPath-based querying has emerged. Our approach aims at optimizing XPath performance through static analysis and syntactic transformation of XPath expressions.
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/inria-00423355
Contributor : Vincent Quint Connect in order to contact the contributor
Submitted on : Friday, October 9, 2009 - 3:54:04 PM
Last modification on : Friday, November 18, 2022 - 9:24:00 AM
Long-term archiving on: : Tuesday, June 15, 2010 - 10:36:29 PM
File
VionDuryGenevesDocEng2004.pdf
Identifiers
Collections
Citation
Pierre Genevès, Jean-Yves Vion-Dury. Logic-Based XPath Optimization. Proceedings of the 2004 ACM symposium on Document Engineering, DocEng 2004, Oct 2004, MilWaukee, WI, United States. pp.211-219, ⟨10.1145/1030397.1030437⟩. ⟨inria-00423355⟩
Share
Metrics
Record views
68
Files downloads
238
