Conference papers
Logic-Based XPath Optimization
Abstract : XPath was introduced by the W3C as a standard language for specifying node selection, matching conditions, and for computing values from an XML document. XPath is now used in many XML standards such as XSLT or the forthcoming XQuery database access language. Since efficient XML content querying is crucial for the performance of almost all XML processing architectures, a growing need for studying high performance XPath-based querying has emerged. Our approach aims at optimizing XPath performance through static analysis and syntactic transformation of XPath expressions.
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/inria-00423381
Contributor : Vincent Quint Connect in order to contact the contributor
Submitted on : Friday, October 9, 2009 - 4:36:58 PM
Last modification on : Wednesday, April 6, 2022 - 3:48:35 PM
Long-term archiving on: : Wednesday, June 16, 2010 - 12:34:40 AM
File
LogicXPathOpt.pdf
Identifiers
  • HAL Id : inria-00423381, version 1
Collections
Citation
Pierre Genevès, Jean-Yves Vion-Dury. Logic-Based XPath Optimization. First International Workshop on High Performance XML Processing, May 2004, New York, United States. ⟨inria-00423381⟩
Share
Metrics
Record views
53
Files downloads
137
