Abstract : We show how the context state of XPath, accessed through the position() and last() pseudo-functions, can be eliminated in most cases by translating references to the context state with an equivalent contextfree expression, and how this enables the use of context state in combination with a subsequent forward-only transformation, allowing for execution of (almost) full XPath on any of the emerging streaming subsets. Specifically we show how the normalization into a core language as proposed in the current W3C Last Call draft of the XPath/XQuery Formal Semantics can be extended such that the context state and reverse axes can be eliminated from the core XPath (and potentially XQuery) language.
