Simultaneous Manifold Learning and Clustering: Grouping White Matter Fiber Tracts Using a Volumetric White Matter Atlas - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Demian Wassermann
Rachid Deriche
  • Fonction : Auteur
  • PersonId : 943743
We propose a new clustering algorithm. This algorithm performs clustering and manifold learning simultaneously by using a graph-theoretical approach to manifold learning. We apply this algorithm in order to cluster white matter fiber tracts obtained from Diffusion Tensor MRI (DT-MRI) through streamline tractography. Our algorithm is able perform clustering of these fiber tracts incorporating information about the shape of the fiber and a priori knowledge as the probability of the fiber belonging to known anatomical structures. This anatomical knowledge is incorporated as a volumetric white matter atlas, in this case LONI's ICBM DTI-81
Fichier non déposé
inria-00430186 , version 1 (06-11-2009)
  • HAL Id : inria-00430186 , version 1
Demian Wassermann, Rachid Deriche. Simultaneous Manifold Learning and Clustering: Grouping White Matter Fiber Tracts Using a Volumetric White Matter Atlas. MICCAI 2008 Workshop - Manifolds in Medical Imaging: Metrics, Learning and Beyond, Oct 2008, New-York, United States. ⟨inria-00430186⟩
115 Consultations
0 Téléchargements
