JTrans, an open-source software for semi-automatic text-to-speech alignment - Archive ouverte HAL Access content directly
Conference Papers Year : 2009
(1) , (1) , (1)
1
Aligning speech corpora with text transcriptions is an important requirement of many speech processing, data mining applications and linguistic researches. Despite recent progress in the field of speech recognition, many linguists still manually align spontaneous and noisy speech recordings to guarantee a good alignment quality. This work proposes an open-source java software with an easy-to-use GUI that integrates dedicated semiautomatic speech alignment algorithms that can be dynamically controlled and guided by the user. The objective of this software is to facilitate and speed up the process of creating and aligning speech corpora.
jtrans.pdf (79.05 Ko) Télécharger le fichier
Dates and versions
inria-00431398 , version 1 (09-05-2016)
Identifiers
  • HAL Id : inria-00431398 , version 1
Cite
Christophe Cerisara, Odile Mella, Dominique Fohr. JTrans, an open-source software for semi-automatic text-to-speech alignment. Proceedings of the 10th Annual Conference of the International Speech Communication Association - Interspeech 2009, Sep 2009, Brighton, United Kingdom. ⟨inria-00431398⟩
853 View
493 Download
Share
