Conference papers
Bio-inspired speed detection and discrimination
Mauricio Cerda 1 Lucas Terissi 2 Bernard Girau 1
1 CORTEX - Neuromimetic intelligence
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : In the field of computer vision, a crucial task is the detection of motion (also called optical flow extraction). This operation allows analysis such as 3D reconstruction, feature tracking, time-to-collision and novelty detection among others. Most of the optical flow extraction techniques work within a finite range of speeds. Usually, the range of detection is extended towards higher speeds by combining some multiscale information in a serial architecture. This serial multi-scale approach suffers from the problem of error propagation related to the number of scales used in the algorithm. On the other hand, biological experiments show that human motion perception seems to follow a parallel multiscale scheme. In this work we present a bio-inspired parallel architecture to perform detection of motion, providing a wide range of operation and avoiding error propagation associated with the serial architecture. To test our algorithm, we perform relative error comparisons between both classical and proposed techniques, showing that the parallel architecture is able to achieve motion detection with results similar to the serial approach.
Document type :
Conference papers
Complete list of metadata
Cited literature [13 references]  Display  Hide  Download
https://hal.inria.fr/inria-00434466
Contributor : Mauricio Cerda Connect in order to contact the contributor
Submitted on : Monday, November 23, 2009 - 1:16:35 PM
Last modification on : Saturday, June 25, 2022 - 9:34:12 AM
Long-term archiving on: : Thursday, June 17, 2010 - 6:24:41 PM
speeddiscrimination.pdf
Identifiers
  • HAL Id : inria-00434466, version 1
  • ARXIV : 0911.4385
Collections
Citation
Mauricio Cerda, Lucas Terissi, Bernard Girau. Bio-inspired speed detection and discrimination. 4th International Conference on Bio-Inspired Models of Network, Information, and Computing Systems - BIONETICS 2009, ICST, Dec 2009, Avignon, France. ⟨inria-00434466⟩
Share
Metrics
Record views
81
Files downloads
313
