A dynamic approach for load balancing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We study how to reach a Nash equilibrium in a load balanc- ing scenario where each task is managed by a selfish agent and attempts to migrate to a machine which will minimize its cost. The cost of a machine is a function of the load on it. The load on a machine is the sum of the weights of the jobs running on it. We prove that Nash equilibria can be learned on that games with incomplete information, using some Lyapunov techniques.
gamecomm.pdf (142.28 Ko) Télécharger le fichier
inria-00435160 , version 1 (23-11-2009)
  • HAL Id : inria-00435160 , version 1
Dominique Barth, Olivier Bournez, Octave Boussaton, Johanne Cohen. A dynamic approach for load balancing. The Third International Workshop on Game Theory in Communication Networks - GAMECOMM 2009, Samson Lasaulce and Yezekael Hayel, Oct 2009, Pise, Italy. ⟨inria-00435160⟩
194 Consultations
257 Téléchargements
