Other publications
The Common Log File (CLF) format for the Session Initiation Protocol (SIP) - draft-gurbani-sipping-clf-01
Gurbani Vijay Burger Eric T. Anjali Humberto Abdelnur 1 Olivier Festor 1
1 MADYNES - Management of dynamic networks and services
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : Well-known web servers such as Apache and web proxies like Squid support event logging using a common log format. The logs produced using these de-facto standard formats are invaluable to system administrators for trouble-shooting a server and tool writers to craft tools that mine the log files and produce reports and trends. Furthermore, these log files can also be used to train anomaly detection systems and feed events into a security event management system. The Session Initiation Protocol does not have a common log format, and as a result, each server supports a distinct log format that makes it unnecessarily complex to produce tools to do trend analysis and security detection. We propose a common log file format for SIP servers that can be used uniformly for proxies, registrars, redirect servers as well as back-to-back user agents.
Document type :
Other publications
Complete list of metadata
https://hal.inria.fr/inria-00436075
Contributor : Olivier Festor Connect in order to contact the contributor
Submitted on : Thursday, November 26, 2009 - 9:12:19 AM
Last modification on : Wednesday, February 2, 2022 - 3:51:48 PM
Identifiers
  • HAL Id : inria-00436075, version 1
Collections
Citation
Gurbani Vijay, Burger Eric, T. Anjali, Humberto Abdelnur, Olivier Festor. The Common Log File (CLF) format for the Session Initiation Protocol (SIP) - draft-gurbani-sipping-clf-01. 2009. ⟨inria-00436075⟩
Share
Metrics
Record views
88
