New interface
Conference papers
Blurred Segments in Gray Level Images for Interactive Line Extraction
Bertrand Kerautret 1 Philippe Even 1
1 ADAGIO - Applying Discrete Algorithms to Genomics and Imagery
LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : Abstract. The recognition of discrete straight segments is a significant topic in the field of discrete geometry and for many applications dealing with geometric feature extraction. It can be performed from noisy binary data using the concept of blurred segments [3,2]. However, to our best knowledge, these algorithms have never been defined to directly extract straight segments in gray level images. This article proposes a solution to extend the recognition by using gray level image information. Although initially intended to be implemented within a semi-automatic line selec- tion tool used in an interactive 3D modeling application, it also meets more general parameter extraction requirements.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00437579
Contributor : Bertrand Kerautret Connect in order to contact the contributor
Submitted on : Monday, November 30, 2009 - 11:31:14 PM
Last modification on : Friday, February 26, 2021 - 3:28:08 PM
Links full text
Identifiers
Collections
Citation
Bertrand Kerautret, Philippe Even. Blurred Segments in Gray Level Images for Interactive Line Extraction. 13th international Workshop on Combinatorial Image Analysis - IWCIA 2009, Nov 2009, Playa del carmen, Mexico. pp.176--186, ⟨10.1007/978-3-642-10210-3_14⟩. ⟨inria-00437579⟩
Share
Metrics
Record views
57
