Component-Based Real-Time Operating System for Embedded Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
As embedded systems must constantly integrate new functionalities, their developement cycles must be based on high-level abstractions, making the software design more flexible. CBSE provides an approach to these new requirements. However, low-level services provided by operating systems are an integral part of embedded applications, furthermore deployed on resource-limited devices. Therefore, the expected benefits of CBSE must not impact on the constraints imposed by the targetted domain, such as memory footprint, energy consumption, and execution time. In this paper, we present the componentization of a legacy industry-established Real-Time Operating System, and how component-based applications are built on top of it. We use the Think framework that allows to produce flexible systems while paying for flexibility only where desired. Performed experimentions show that the induced overhead is negligeable.
Loiret_Navas_Babau_Lobry-CBSE09.pdf (223.72 Ko) Télécharger le fichier
inria-00437949 , version 1 (01-12-2009)
  • HAL Id : inria-00437949 , version 1
Frédéric Loiret, Juan Navas, Jean-Philippe Babau, Olivier Lobry. Component-Based Real-Time Operating System for Embedded Applications. 12th International ACM SIGSOFT Symposium on Component-Based Software Engineering (CBSE'09), Jun 2009, East Stroudsburg, United States. pp.209-226. ⟨inria-00437949⟩
370 Consultations
1172 Téléchargements
