An L(1/3) algorithm for ideal class group and regulator computation in certain number fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics of Computation Année : 2014
We analyse the complexity of the computation of the class group structure, regulator, and a system of fundamental units of a certain class of number fields. Our approach differs from Buchmann's, who proved a complexity bound of L(1/2,O(1)) when the discriminant tends to infinity with fixed degree. We achieve a subexponential complexity in O(L(1/3,O(1))) when both the discriminant and the degree of the extension tend to infinity by using techniques due to Enge and Gaudry in the context of algebraic curves over finite fields.
preprint.pdf (199.76 Ko) Télécharger le fichier
inria-00440223 , version 1 (09-12-2009)
  • HAL Id : inria-00440223 , version 1
  • ARXIV : 0912.1927
Jean-François Biasse. An L(1/3) algorithm for ideal class group and regulator computation in certain number fields. Mathematics of Computation, 2014, 83 (288), pp.2005-2031. ⟨inria-00440223⟩
210 Consultations
185 Téléchargements
