Abstract : The number of people that develop Alzheimer's Disease (AD) is rapidly rising, while the initial diagnosis and care of AD patients typically falls on non-specialist and still taking up to 3-5 years before being referred to specialists. An urgent need thus exists to develop methods to extract accurate and robust biomarkers from low-cost and non intrusive modalities such as electroencephalograms (EEGs). Contributions of this paper are three-fold. First we review 8 promising methods for early diagnosis of AD and undertake a performance evaluation using ROC analysis. We find that fractal dimension (AUC = 0.989), zero crossing interval (AUC = 0.980) and spectrum analysis of power alpha/theta ratio (Pwrα,θ)(AUC = 0.975) perform best. with all three having sensitivity and specificity higher than 94%. We plot ROC curve with 95% confidence contours because of the small size of our data set (17 AD and 24 NOLD). Second, we investigate a fusion approach to combine these methods, using a logistic regression model, into one single more accurate biomarker (AUC = 1.0). Thirdly, to help support the distribution and use of these methods for early detection and care of AD, we developed them as web-services, integrated into online tools available from the BIOPATTERN project portal (www.biopattern.org).
